Comparing Experimental and Computational results.
Old   September 27, 2007, 12:08
Default Comparing Experimental and Computational results.
New
I am trying to compare experimental results of a Mach 2 jet with nozzle pressure ratio(NPR) = 1.2 with the computational results , my problem is : 1) Say the freestream Mach number is 0.05 what values of pressure, temperature do I use in order to initialise the computational flow field? 2) Given the jet exit conditions (M=2 and NPR=1.2) how can I calculate the static temperature and static pressure values ?
Thank you
Experimental data mapping. paka OpenFOAM 5 January 13, 2011 16:27
Visualizing/comparing experimental to computational results f-w Main CFD Forum 0 May 29, 2009 16:36
computational domain & boundary condition novice Main CFD Forum 0 May 8, 2006 19:30
Verifying fan test results with CFD Jenny FLUENT 0 January 17, 2006 00:52
experimental /any result of round jet in a co-flow Lakshmi Kanth Main CFD Forum 3 September 26, 2005 13:03
