supersonic flows
Old   October 11, 2007, 21:11
Default supersonic flows
Shuo
What type of supersonic flows can be modelled accurately using Euler equations other than supersonic jets? Are there experimental data available for these flow?
Cheers, Shuo
Old   October 12, 2007, 09:17
Default Re: supersonic flows
pc
First of all, you shouldn't use the Euler equations for jets because most jets are turbulent.
Second, the Euler equations are appropriate for any supersonic flow where viscous effects are negligible.
Third, available experimental data will depend on what class of problem you're looking for.
Old   October 12, 2007, 19:30
shuo
I read that Euler equations are OK for supersonic jets. I am modelling gas-particle supersonic impinging jets.
Old   October 12, 2007, 20:57
pc
If your particles are large enough that they are not affected by the gas phase, an Euler assumption may be sufficient. However if the particles are smaller, by neglecting turbulence, your calculations will omit the radial spread of the particles due to turbulent interactions. Particle trajectories are known to be affected (dispersed) by turbulent eddies.
Old   October 12, 2007, 21:17
shuo
What is the definition of 'small' particles. The particles in the flow i am looking at will be of the order 1-50 micrometers. Is there a reference for the turbulence comment?
Shuo
Old   October 12, 2007, 22:53
pc
It depends on the particle density, but I would say anything below 20 microns will definitely be subject to dispersion by turbulence. There are numerous papers in the literature on turbulent dispersion of particles in shear layers and jets, but most papers I know of are at low speeds. Look up Stochastic Separated Flow (SSF) models.
Good luck.
how to use openfoam for supersonic reacting flows? chandramurthy OpenFOAM Running, Solving & CFD 9 December 11, 2018 04:28
LES applied to supersonic flows pkt Main CFD Forum 3 January 16, 2008 08:36
CFD code for supersonic flows hedy Main CFD Forum 9 April 16, 2007 10:56
supersonic non-ideal gas flows nik FLUENT 0 April 20, 2004 05:14
Supersonic Jet Flows Danny Tan FLUENT 0 November 30, 2001 21:01
