4-digit NACA airfoil: Trailing edge of the airfoil is not quite zero |
September 10, 2014, 15:55 |
#1 | |
Rep Power: 12 |
Wikipedia says:
September 14, 2014, 16:06 |
Julian Langowski
Rep Power: 14 |
Dear Sisi,
book recommendation: Abbot and Doenhoff - Theory of wing sections There you find (almost) everything on NACA airfoils and also the formulas for contours. Best regards Julian
πάντα ῥεῖ - Heraclitus |
September 20, 2014, 05:07 |
Rep Power: 12 |
Thank you for your response. Just borrowed this book. Unfortunately it contains no information on "Modifying the last coefficient"...
September 23, 2014, 09:02 |
Troy Snyder
Rep Power: 18 |
Rather than modify the coefficient of the equation used to generate the profile, you can linearly extrapolate the sharp trailing edge point.
September 24, 2014, 20:13 |
Martin Hegedus
Rep Power: 19 |
October 1, 2014, 10:00 |
#6 | |||
Rep Power: 12 |
Thanks for your replies!
http://www.pdas.com/naca456thick4.html Quote:
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[DesignModeler] 3mm Trailing edge radius on closed airfoil | henrikdahlberg | ANSYS Meshing & Geometry | 1 | June 10, 2015 05:04 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Leading edge and trailing edge of an airfoil rotor blade | Jun_Milan | CFX | 0 | July 10, 2014 23:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
