Data Aquisition
Old   October 15, 2007, 12:24
Default Data Aquisition
Neetin Lad
To all
I have steady and unsteady flow around a 2D cylinder (cross section) in FLUENT 6.3. and i have aquired results. i have then changed the geometrical conditions of the ciruclar to achieve a new effect on the flow.
1) Is it possible to produce an X-Y plots of say pressure and velocities in the X and Y direction from both cases in one graph.
2) Is it possible to aquire the data on both sets, and take one away from the other to achieve a graph of the "difference" of pressures or velocities in a certain direction.
Thank you
Neetin Lad.
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
export data at nodes Meenu FLUENT 1 December 30, 2011 01:24
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 13:50
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
