October 23, 2007, 05:26 |
ODD-EVEN DECOUPLING
Dear all, could someone explain to me the odd even decoupling problem? What it is When it can be found (compressible, incompressible) On which grids Is lumping the only solution? Thank you Al
October 25, 2007, 10:58 |
Re: ODD-EVEN DECOUPLING
ODD-EVEN DECOUPLING is seen for pressure solution in incompressible flows. This is a numerical issue caused by the way derivatives are computed say on a finite difference grid where pressure and velocities are calculated at grid nodes. You can read more about it in the book "Numerical Heat Transfer" by SV Patankar. To avoid this one usually uses a staggared grid where velocites are defined on cell faces and pressure at the cell center.
extrudeMesh - odd behaviour | grjmell | OpenFOAM | 0 | September 20, 2011 08:41 |
help the Gradient odd in zone interface | shaoxianjun | FLUENT | 0 | October 15, 2009 22:17 |
Odd Even Decoupling Validation | Sachin | Main CFD Forum | 1 | October 8, 2005 06:58 |
Odd-even decoupling of cells | Peter | Main CFD Forum | 2 | June 1, 2001 13:19 |
pressure velocity decoupling | Frank Muldoon | Main CFD Forum | 4 | February 4, 1999 11:25 |
