Initial k & epsilon for engine simulation
Old   November 26, 2007, 05:32
Default Initial k & epsilon for engine simulation
Tomislav Sencic
I would like to simulate the combustion in internal combustion engine. What are the initial values (how do I find or calculate them) to set for k and epsilon for the k-epsilon turbolence model? Any information is apreciated
Old   November 27, 2007, 05:21
Default Re: Initial k & epsilon for engine simulation
Hrvoje Jasak
Choose k be using 3-5% of the mean velocity as the velocity fluctuation. You can then do
k = 3/2 uPrime^2
to get k.
For a length-scale, choose a fraction (say a quarter) of your inlet manifold diameter or a bit less of the cylinder diameter if you've got no manifolds - L = 1 cm is a decent size for a car engine. You can then estimate epsilon as:
epsilon = Cmu^0.75 k^1.5/L
Cmu is (of course) 0.09.
In reality it does not matter much what you choose. The whole setup is really a turbulence-making machine (you want good mixing, right?) so the initial field will be quickly replaced by "real" turbulence. When that happens, you can check that your estimated k and epsilon with some more realistic data.
Enjoy,
Hrv
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 10:47
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
