November 4, 2007, 21:52 |
separation
For a convergent solution (boundary layer atmospheric flow); is it possible to determine real world separation?
From my understanding in the real world any separation is usually the result of a turbulent eddy, and is a transient phenomena, and hence will not converge. Only in special circumstances will separation occur where a stable eddy results, this would be similar to a standing wave. Or have I got this all wrong? |
November 4, 2007, 22:46 |
Re: separation
Separation can occur for laminar flows, and hence a turbulent eddy is not required. Separation is also possible for a steady flow - go look at results for low Re cylinder flows. In the most basic sense, separation occurs when the kinetic energy of the flow is insufficient to overcome the adverse pressure gradient.
November 8, 2007, 03:27 |
Re: separation
your apprehension is mostly true. the steadiness of a bubble or generally a vortex is in direct relation with the Reynolds number of flow and more importantly the adverse pressure gradient of geometry which is producing separation bubble. on the other word if you assume a constant case ( same geometry ) the factor which is dominant in steadiness of phenomenon is Re .
Display Modes | |
Separation Point over a NACA 0012 | Franny | CFX | 9 | October 12, 2011 11:01 |
wall function and flow separation | O.D.Y. | FLUENT | 1 | October 3, 2011 17:27 |
How to identify flow separation region? | Cheng | CFX | 2 | November 29, 2006 08:26 |
Separation | An Modh Coinniolach | FLUENT | 4 | April 1, 2002 12:31 |
Euler + separation again | Oliver | Main CFD Forum | 23 | June 19, 2001 13:47 |
