axisymmtric numerical model
Old   November 20, 2007, 00:35
Default axisymmtric numerical model
Lokanath
I am getting convergence problem for axisymmetric numerical model for a simple pipe flow problem. the boundary conditions i have used are as follows
at x=0 u=1,v=0 delp/delx=0 delpdash/dx=0
at x=l delu/del/x=0, delv/delx=0 p=0 pdash=0
at r=0 delu/delr=0 v=o delp/dy=0 delpdash/dy=0
at r=R wall
can some one tell, how this ll differ from the code of rectengular co-ordinate.
Now i m trying with changing the area of the face and voulme of the cell and rest all the code is same.
Thank you in advance.
Old   November 20, 2007, 08:52
Default Re: axisymmtric numerical model
otd
What is pdash?
You should be solving momentum equations for u and v plus a continuity constraint on the solution that determines the pressure distribution (to within a constant - it's the pressure gradient that matters).
Old   November 20, 2007, 13:27
Lokanath
Thank you OTD for the reply.
Pdash is the correction in the pressure.
I am doing the same solving the continuity and u,v momentum equation in collocated grid using predictor-corrector pressure correction algorithm..
my question was how it differs from the algorithm for cartesian co-ordinate system.
Now for axisymmetric the change i have done is in the area and volume of the cell.
is there anything more other that.....
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
species transport model or mixture model? achaokaoyan Main CFD Forum 0 July 10, 2010 10:52
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Feasiblity of CFD model for Real-Time applications la mimi Main CFD Forum 2 January 28, 2007 04:49
