Initial conditionfor turbulent channel flow in LES
Old   November 30, 2007, 12:04
Default Initial conditionfor turbulent channel flow in LES
pankaj saha
hi, i am solving fully developed plane channel flow by LES. I am using periodic boundary condition in steramwise(x-direction),and spanwise(z-direction).A no slip b.c for top and bottom wall(y-direction).
For initial condition i am taking a fully developed mean profile with random perturbation for the u-component (streamwise)of velocity. and v=0,w=0. like as follows...
For the whole domain---- u(x,y,z)=(1-y**8)+0.005*(RAND(x,y,z)-0.5 v(x,y,z)=0.0 w(x,y,z)=0.0
And in fortran programming language---
IND=0
do 55 i=1,iim
do 55 j=1,jim
do 55 k=1,kim
u(i,j,k)=(1-y(j)**8)+0.005*(RAND(IND)-0.5)
v(i,j,k)=0.0
w(i,j,k)=0.0
p(i,j,k)=1.0
IND=IND+1
55 continue
i,j,k--is spatial grid in three directions
iim=maximum grid no in x-direction
jim=maximum grid no in y-direction
kim=maximum grid no in z-direction
RAND(IND)------is a inbuilt function in fortran. As, the value of IND , change in the loop--then RAND(IND), will give a value , between--0.0-1.0
my question is---------
1. Is my approach correct.
2.Do i need random values for v and w velocity component.
3.Do i need to change the random function.
Please help me. A warm thanks in advance..
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 02:11
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
