Development of static pressure
Old   December 6, 2007, 12:36
Default Development of static pressure
Parag Gadgil
I have an intake geometry which has two air inlets.I am specifying Pressure inlet as the boundary condition for both inlets.
The problem is that, the static pressure developed after the converged solution at the two inlets is different eventhough the total pressure specified in the Boundary conditions panel for both the inlets is the same assuming that the initial velocity at both the inlets has to be zero.
Is there any other way to specify the different boundary conditions for two different inlets.
Regards, Parag
Old   December 10, 2007, 17:42
Default Re: Development of static pressure
gemsma
You can specify different total pressure(and temperature). In your final result the velocity at the two inlets are not the same(and not zero, otherwise it is not inlet), that is why the static pressure is different.
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
