negative mesh elements in turbogrid
Old   December 16, 2014, 00:03
Default negative mesh elements in turbogrid
sarath
sarath_b is on a distinguished road
Hello everyone,
i have done meshing for axial turbine rotror using 'traditional topology with control points'. it is showing mesh elements with negative volumes. i have tried adjusting control points but in vain. some of the members in previous threads suggested to use 'template' button, which i didnt find in my turogrid . Please suggest me how can I avoid formation of negative volume mesh elements.
Thanks in advance.
sarath_b is offline   Reply With Quote
Old   October 28, 2020, 10:48
Unhappy negative mesh elements in turbogrid
Sohaib H Khan
shk09 is on a distinguished road
it is october 2020 and still couldnt find a viable solution to the above prolem.
shk09 is offline   Reply With Quote
Old   October 31, 2020, 19:22
Sebastian Engel
bluebase will become famous soon enough
Hi Sohaib,
The original question did not have a lot of useful information in it. And the original poster did not use a suggested subforum.
Using subforums for software specific questions significantly increases the chance that a knowledgeable member reads it and might be able to answer.
Therefore, i suggest you to open a new thread in the ansys meshing subforum and describe your problem in detail, ideally with pictures, what you have tried to solve the problem and what other symptoms you have found (error messages, locations of invalid elements).
In most subforums there is also a sticky post with some information on how to ask good questions (to increase the chance to motivate someone to answer).
Best regards,
Sebastian
bluebase is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Fluent dynamic mesh 'remeshing' method for pyramid elements DarrenC FLUENT 14 December 11, 2015 04:58
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Negative Elements in mesh generated by Gridgen gracerlima Pointwise & Gridgen 3 March 16, 2010 20:38
