The selecion of turbulent model in compressible supersonic jet |
December 22, 2014, 10:07 |
Leeoo
Rep Power: 11 |
Dear Friends,
I want simulate the compressible supersonic jet in Laval tube by CFD. I have used the standard k-e, realizable k-e, standard k-w and sst k-w turbulent model, but the simulation results of the above turbulence models were all different. Can someone tell me which turbulence model I should choose? I really hope to get reply! |
December 25, 2014, 14:43 |
Hamid Zoka
Rep Power: 18 |
please let me know:
1- Did you use standard formulation of the turbulence models mentioned or a revised formulation which considers compressibilty effects of fluid flow? Generally in reference text books incompressible turbulence models are formulated. 2- what do you expect of the results and how the turbulence models are different in their predictions? are there some unrealistic results? results |
December 26, 2014, 20:36 |
N/A
Rep Power: 17 |
The SST model is known to perform well for these flows. However, there may be newer models which give improved predictions. I would suggest you do perform a literature search over the past 6-8 years on similar simulations and then decide on the model.
turbulents model |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Jet in Supersonic Crossflow | choozr | FLUENT | 1 | October 19, 2014 11:35 |
2d axisymmetric simulation of supersonic jet on liquid surface using VOF model | DKanungo | Fluent Multiphase | 0 | June 20, 2014 02:15 |
Turbulence model for supersonic jet | Danny Tandra | Main CFD Forum | 3 | August 24, 2001 04:10 |
Turbulent model of supersonic free jet | GAZZAH Mohamed Hichem | Main CFD Forum | 2 | August 18, 2000 15:43 |
