turbine simulatino
Old   November 25, 2014, 10:31
Default turbine simulatino
Sharon Wilcox
CFDturbomachinery is on a distinguished road
Hi guys,
At the inlet of the turbine, I want to specify head and discharge (mass flow rate) in CFX; is there a way to do this?
CFDturbomachinery is offline   Reply With Quote
Old   November 25, 2014, 16:43
Khalil M Khalil
KMK327 is on a distinguished road
What is the turbine type you are working on?
KMK327 is offline   Reply With Quote
Old   December 24, 2014, 18:09
Sharon Wilcox
I am simulating francis water turbine
Old   December 25, 2014, 14:33
Hamid Zoka
Hamidzoka is on a distinguished road
simultaneous setting of mass flow and pressure (head) at the inlet makes your simulation over constrained. unless you set pressure (head) at the inlet an mass flow as the outlet boundary condition. If so, you will have no control on outlet static pressure level.
regards
Hamidzoka is offline   Reply With Quote
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 05:27
Using 6dof for 3D turbine rotation mg.mithun Fluent UDF and Scheme Programming 8 July 24, 2018 00:53
[TGrid] Water Turbine meshed in TurboGrid: Geometry and Topology issues ama294 ANSYS Meshing & Geometry 12 September 29, 2014 13:23
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
