SIMPLE algorithm code not converging
Old   December 28, 2014, 14:29
Default SIMPLE algorithm code not converging
Md. Intishar's Avatar
Md. Intishar Rahman
Md. Intishar is on a distinguished road
Hello CFD Coders,
I am writing a SIMPLE algorithm code on Matlab for my undergrad project. I am using the colocated formulations on a finite differencing method. I am using Rhie-Chow interpolation for the face velocity interpolation.
D
I am conserving total mass in the overall domain by setting the Outlet Node value of U velocity as:
U(I,NI)= U(I,NI-1) * (sum(U(:,1))/sum(U(:,NI-1)) ;
This is applied in each TDMA iteration loop, just after the calculation of the value of U(I,NI-1)
In the Pressure Correction code, the momentum interpolated face velocities are computed as follows :
if J==LNC+1;
VPE= U(I,J+1);
else VPE=(UEF) + 0.5*(((DY/APU(I,J) +DY/APU(I,J+1)))*(PP-P(I,J+1))) +0.5*(-(DX/APU(I,J)) *(PWF -PEF) -(DX/APU(I,J+1)) *(PEF-PEE) );
end
if J==2;
VPW= U(I,J-1);
else VPW=(UWF) + 0.5*(((DY/APU(I,J) +DY/APU(I,J-1)))*(P(I,J-1)-PP)) +0.5*(-(DX/APU(I,J)) *(PWF -PEF) -(DX/APU(I,J-1)) *(PWW-PWF) );
end
if I==LNR+1;
VPN= V(I+1,J);
else VPN=(VNF) + 0.5*(((DX/APV(I,J) + DX/APV(I+1,J)))*(PP-P(I+1,J))) +0.5*(-(DX/APV(I,J)) *(PSF -PNF) -(DX/APV(I+1,J)) *(PNF-PNN) );
end
if I==2;
VPS= V(I-1,J);
else VPS=(VSF) + 0.5*(((DX/APV(I,J) + DX/APV(I-1,J)))*(P(I-1,J)-PP)) +0.5*(-(DX/APV(I,J)) *(PSF -PNF) -(DX/APV(I-1,J)) *(PSS-PSF) );
end
and the co-efficients are :
AE(I,J)= RHO*DFe* DY;
AW(I,J)= RHO*DFw* DY;
AN(I,J)= RHO*DFn* DX;
AS(I,J)= RHO*DFs* DX;
where, DFe = (DY/APU(I,J) + DY/APU(I,J+1))
I am using momentum equation under-relaxation factor : .1 and pressure under-relaxation factor: 0.1
The pressure is corrected as:
P= P_star + pressure_UR*p';
the nodal velocities are also under-relaxed as:
U(I,J)= U(I,J)-((DX)/APU(I,J))*(PPE-PPW);
V(I,J)= V(I,J)-((DX)/APV(I,J))*(PPN-PPS);
where PPE,PPW,PPN,PPS are the pressure correction values at the faces
The momentum equation are under-relaxed as:
AP= AP./RF ;
B = B + (1-RF)*AP.*SPECIES; % SPECIES=U for U velocity and SPECIES=V for V velocity
I have used all the procedures, instructionss required for the SIMPLE and similar coding, following CFD book of Versteeg and Malalakera, and Numerical Methods in Heat, Mass, and Momentum Transfer by J.Y. Murthi and every other books and instruction I get at hand.
Reading a thread on CFD ONLINE I also double cheked the mass conserving 'Outlet Condition'.
At this point I absolutely have no idea why my code is not converging.
I used the difference of U and V velocity to determine the convergence, DIFF= (abs(U-U_initial)+abs(V-V_initial))*0.5;
Also as outlined in the CFD book of Anil Date I used 10 iterations for pressure correction but the system still, on the whole, diverges.
Can someone kindly help me to fix this problem? I am in urgent need.
Thanks in advance.
Md. Intishar is offline   Reply With Quote
Old   December 31, 2014, 04:03
Md. Intishar Rahman
Not convinced if CFD online has ever been designed for the slightest purpose of the young coders. :what:
Old   January 21, 2015, 13:28
Michael Moor
michaelmoor.aero is on a distinguished road
Thank-you for your email. As you may have seen from my previous posts, I am happy to give you the work that i did on a backward staggered grid for 2D laminar flow.
Unfortunately i have not worked on CFD programming for a few years now, however if asked a question on the code that i have, which a member Dr. Ding PEng helped me with, I might be able to help! Working now, I have very little time I'm afraid!
I also do not have my copy of Versteg with me, and so cannot check the code against the backward staggered grid. From reading through your code, you seem to have a good grasp of the process....
If you supplied me with an email address, I would be happy to forward you my code, which is quite explicitly explained.
Kind regards,
Michael
michaelmoor.aero is offline   Reply With Quote
Old   January 22, 2015, 13:34
G. S.
gerardosrez is on a distinguished road
Hello Mike, long time no talk to you, I see you are still active...How is it going?? Still in contact with Ding???
Best regards...
By the way I strongly recommend Michael on CFD programming...
gerardosrez is offline   Reply With Quote
code for SIMPLE algorithm - 2D Lid driven cavity flow problem - Collocated grid h_amooie OpenFOAM Programming & Development 1 January 22, 2022 11:33
A simple DNS code aroma Main CFD Forum 2 September 16, 2014 23:29
SIMPLE algorithm instability at low viscosities kooroshg1 Main CFD Forum 7 July 10, 2014 03:00
SIMPLE algorithm not converging. sgp Main CFD Forum 4 August 12, 2010 21:06
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
