January 7, 2015, 20:43 |
Is it a turbulent flow or laminar flow?
Hi guys,
I am trying to simulate the flow through a heat sink with several fins. the geometry model is shown as the below picture. 1.jpg According to the length of the fin, the Reynolds number is 9e+4, which is less than the number of transition. so, the flow should be laminar? I'm not sure if I should treat it as a laminar flow, and then use laminar model to simulate the flow? What's more, the flow starts from a fan. Is it resonable that the flow has become turbulent when it leaves the fan blade? so I sould simulate it by using a turbulent model. Thanks in advance. |
January 19, 2015, 19:42 |
Could anyone give me any suggestion?
Or.. is there anything I didn't descrbe clearly? |
January 19, 2015, 20:00 |
#3 | |
Troy Snyder
Rep Power: 18 |
inline with the fins or perpendicular. If there is any question about laminar or turbulent, you may want to run laminar flow as an initial limiting case. The laminar case should produce the lowest heat flux values without the additional energy transport due to the motion of turbulent eddies. |
January 20, 2015, 01:55 |
Firas
Rep Power: 11 |
Laminar flow will be suitable for this case without caring of near fan treatment ....
January 20, 2015, 23:34 |
#5 | |
Venkatesh Devaraj
Rep Power: 11 |
Note: Freestream turbulence should be taken into account before deciding whether it a laminar or turbulent flow. Reynolds number doesn't alone play the role. |
January 22, 2015, 18:24 |
#6 | |
January 22, 2015, 19:32 |
#7 | |
Hi, Troy
Thank you~~The flow the inline with fin. Yes, I agree with you. The heat transfer in laminar case is smaller than turbulent one. But I wanna know the real boundary layer thickness on the fins, so it's essential to know the flow model in advance. And I think the best suitable gap between fins, shoud be the double of the boundary layer thickness. Quote:
January 22, 2015, 19:37 |
Hi Firas, I am still a bit confused about this.
If the free stream is disturbed by the fan, hasn't it become turbulent flow in front of the fin? so, the flow around the fins should be turbulent since the turbulent flow won't transit to laminar flow even I don't care about the flow near the fan. But I'm not sure about my opinion. |
January 22, 2015, 19:47 |
#9 | |
yes, Venkatesh , I totally agree with you. And I want have a deeper discussion about this topic.
How should we make a appraisal of the disturb if it's big enough to triggle the transition? and how should we assess the turbulent intensity of the free stream after it leaves the fan? (you know, it may be the key parameters to set the bc in FLUENT) Quote:
January 22, 2015, 19:52 |
the heat sink is about 400 mm long , 300 mm width and 200 mm high.
the gap between the fins is about 5 mm. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Do formula for Laminar and Turbulent Flow Calculation formulae change with Fluid | Parag Gadgil | FLUENT | 0 | June 19, 2012 07:07 |
Turbulent / laminar flow | broken | Main CFD Forum | 0 | May 9, 2012 06:44 |
Can I use turbulent model to solve a laminar flow? | nikhil | FLUENT | 5 | February 1, 2011 10:42 |
Turbulent viscosity in Laminar Flow | Mike | Main CFD Forum | 8 | April 12, 2010 11:40 |
