February 4, 2015, 00:08 |
real comparison in fortran not working
Alan Smith
I have a Fortran 95 program (using silverfrost compiler) which hits an overflow because 2 variables are the same. Should be easy to manage that, right? But all my comparisons don't work, see code below.
The statement that should pick it up is: if (abs(tanh(SthisX)-tanh(SlastX)).EQ.zero) ...... but whenever tanh(SthisX) becomes the same as tanh(SlastX), the program crashes with an overflow - AFTER the if condition. IE the If doesn't pick it up. Any ideas? Thanks -------------------------------------------------- program secTanHroots !Summary: find positive root of tanh(C) using Secant method implicit none integer, parameter :: dp = selected_real_kind(15, 307) real(kind=dp) :: guess, SthisX, SnextX, SlastX, Sdiff real(kind=dp), parameter :: zero=TINY(0.0), infinity=HUGE(0.0), root=0.0 real :: C=5 integer :: iter integer, parameter :: n=58 character(len=n ) :: stars=REPEAT('*',n) !----- header ---- print *, " " print *, 'Program secTanHroots starts' print 5, 'Enter a guess to estimate the positive root of Tanh(', C,')' print *, ' (enter a negative number to stop)' read (*,*) guess print *, stars print *, " " print 10, 'Iter.','X(i) ', 'X(i+1)"root"', 'tanh(SthisX)','tanh(SlastX)', 'diff' !----- end header ---- do while (guess.GE.0) ! allows trials of diff. values of guess !----- Initialise ---- SthisX= guess Sdiff=1 SlastX=1 iter=0 Do while (abs(Sdiff).GT.zero) iter=iter+1 print *, tanh(SthisX)-tanh(SlastX) if (abs(tanh(SthisX)-tanh(SlastX)).EQ.zero) then print *, '++++++++++++++++ overflow +++++++++++++++' go to 100 end if SnextX= SthisX-tanh(SthisX)*((SthisX-SlastX)/(tanh(SthisX)-tanh(SlastX))) !Secant method Sdiff = root-SnextX print 20, iter, SthisX, SnextX, tanh(SthisX),tanh(SlastX), Sdiff SlastX=SthisX SthisX=SnextX if (iter.GT.20) then ! to prevent overrun print *, 'forced stop, cntr > 20' stop end if end do 100 print *, stars print *, " " print *, 'Enter another guess (or negative number to stop)' read *, guess print *, " " end do print *, 'User selected end' print *, stars 5 format (A, F3.1,A) 10 format (A, 4X,5(A, 6X)) 20 format (I2, 5(3X, ES14.6)) end program secTanHroots |
February 7, 2015, 12:15 |
Peter
Rep Power: 11 |
If "SthisX == SlastX" then you are dividing by zero.
SnextX= SthisX-tanh(SthisX)*((SthisX-SlastX)/(tanh(SthisX)-tanh(SlastX))) !Secant method Code:
if (abs(sthisx - slastx) <= epsilon(real) then ... Peter |
February 7, 2015, 18:53 |
working now
Alan Smith
The .LE. instead of .EQ. sorted it thanks. I guess I was in denial about comparing reals in Fortran :-)
fortran code, real comparison, silerfrost |
Hydrogen storage by metal hydride | longbk | FLUENT | 12 | August 1, 2023 20:13 |
NOx UDF | Abhishek Asthana | FLUENT | 5 | October 12, 2016 07:24 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
how to hook this udf | shanu | FLUENT | 1 | August 26, 2011 10:48 |
Please help me run UDF code for source | Suga | FLUENT | 1 | February 3, 2006 03:40 |
