TVD time accuracy
Old   February 27, 2008, 22:23
Default TVD time accuracy
Shuo
I am currently using Yees upwind/symmetric TVD schemes to model a supersonic impinging jet and integrating in time using 3rd order Runge-Kutta. How can i ensure 'TIME accurate' simulations?
Shuo
Old   March 1, 2008, 09:26
Default Re: TVD time accuracy
ganesh
Dear Shuo,
If you running with third order RK in explicit mode, you are automatically time accurate, with the only constraint that your simulation would be lot slower due to conditional stability of RK3 arising from CFL criterion. Generally researchers overcome the CFL barrier by using implicit schemes, which however destroys time accuracy. It is then that you need to be more careful in ensurin time accuracy.
Hope this helps
Regards,
Ganesh
Old   March 1, 2008, 17:00
shuo
Thanks for the reponse, Ganesh. I wanted to make sure it was time accurate. Shuo
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Time Accuracy of the NITA - FRACTIONAL STEP method Paolo Lampitella FLUENT 1 March 19, 2008 05:45
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
TVD student Main CFD Forum 6 September 9, 2002 09:19
