February 23, 2015, 06:08 |
Flow through nozzle
Rahul Singh
Rep Power: 11 |
I tried solving 1D nozzle flow using Euler equations using finite difference scheme and after convergence of solution i found that at throat Mach No. is 0.9445 and not 1. It's a subsonic-Supersonic nozzle. Though the results are matching with the paper i am trying to reproduce the results of, it doesn't seems right. Is there any problem in-built in solving Euler for varying area section or am i doing anything wrong?
February 23, 2015, 09:58 |
Rep Power: 18 |
Are you using boundary conditions that would cause the flow to choke? What is the exit Mach number? Are you sure that you are getting the throat Mach number at the true minimum area?
February 24, 2015, 07:01 |
Rahul Singh
Rep Power: 11 |
Mach no. at exit is 1.3 and throat mach no. is not at the minimum area.
February 24, 2015, 10:05 |
Rep Power: 18 |
The flow will choke at the minimum area. If your throat is not at the minimum area then it is not the throat. How is your throat Mach number not at the minimum area?
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Having Problem solving 2D supersonic flow around a plug nozzle | chrislloyd | FLUENT | 7 | July 22, 2015 13:09 |
calculate a nozzle flow using rhoCentralFoam | hg2lf | OpenFOAM | 0 | October 25, 2012 21:26 |
Nozzle Flow Simulation | Winnie | CFX | 0 | August 24, 2007 10:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
