Turbulence kinetic energy and dissipation rate - problem with computation
Old   March 6, 2015, 04:04
Default Turbulence kinetic energy and dissipation rate - problem with computation
jiri kozak
Kozan is on a distinguished road
Hello!
I'm quite new in OpenFoam and Python, therefore I have decided to write short script for the turbulence kinetic energy and dissipation rate computation.Code of the sripts follows:
def VypocetTurbVelicin(velocity, hydraulic_diameter, mu):
reynolds = (velocity * hydraulic_diameter)/mu
cmu = 0.09
intensity = 0.05
fluct_velocity = intensity * velocity
global k
k = 3/2 * ((fluct_velocity)**2)
turbulence_lengthScale = 0.038 * hydraulic_diameter
global epsilon
epsilon = (cmu * k**(3/2))/turbulence_lengthScale
return k, epsilon
k = None
velocity = float(raw_input("Velocity: "))
hydraulic_diameter = float(raw_input("Hydraulic diamter: "))
mu = float(raw_input("Kinematic viscosity : "))
print "turbulence kinetic energy: " + str(k)
print "turbulence dissipation rate: " + str(epsilon)
Problem is that the results of my script are different compared to the calculator which is available on the cfd-online (http://www.cfd-online.com/Tools/turbulence.php)
I can't find the problem. Thank you very much for any advice
For example results for
vel = 4.2 m.s^(-1)
visc = 1E-6 m^(2).s^(-1)
hydraulic diameter = 0.3 m
turbulence intensity = 5%
are:
My script:
k = 0.0441
eps = 0.348157894737
CFD online calculator
(Turbulence variables (k, ε, ω) from turbulence intensity (Tu), length-scale (TuL) and freestream velocity (U∞)):
k = 0.06615000000000001
eps = 0.13431744774423365
Kozan is offline   Reply With Quote
dissipation rate, epsilon, kinetic energy, openfoam, turbulence
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
change a variable in dissipation tem of turbulence model behest Fluent UDF and Scheme Programming 0 March 28, 2014 08:31
how to define the turbulent kinetic energy and turbulent dissipation rate? fanke FLOW-3D 4 March 26, 2013 20:40
turbulent kinetic energy and turbulent dissipation rate D_L Main CFD Forum 5 July 17, 2010 02:35
how to decide boundary condition of turbulence energy dissipation rate? Vincent B. Main CFD Forum 5 October 28, 1999 04:07
