Time Dependent Temperature Dependent BC Analysis
Old   March 27, 2008, 01:03
Default Time Dependent Temperature Dependent BC Analysis
RP
Hi
I have a peculiar problem to resolve. I have a heat source whose Q is dependent on its Centroid Temperature. To cool this heat source, I have a fixed cooler. I can perform a steady state analysis for the same. Fine upto this point.
But If I want to perform a transient analysis, with the same Q being dependent on time also, Is it possible? Does it physically make any sense. I believe I am driving Q and trying to resolve it in Temperature and time dimensions.
If it is possible, can you let us know how can be it made to work?
Thanks
RP
Old   March 28, 2008, 01:22
Default Re: Time Dependent Temperature Dependent BC Analys
RP
I will make it simple to understand.
On a graph,
On longitude axis, I have temperature.
On Latitude axis, I have time
On Altitude axis, I have Q (Heat Flux)
If we plot the data, graph looks like a surface plot in Excel.
Can we perform a transient analysis in this case. Or will it be pseudo steady analysis ? How this needs to be setup?
Any pointers or help in this direction is highly appreciated.
Thanks
RP
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 08:33
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
