flying object with a ribbon attached
Old   November 1, 1999, 01:07
Default flying object with a ribbon attached
Dong
Hi folks, I intend to simulate the 6-DOF motion for a flying object with a ribbon attached at its tail. Here the ribbon behaves like a stablizer. In this problem the fluid dynamics is coupled with the 6-DOF motion of the flying object, and the flexible ribbon changes its shape and relative positions to the flying object. If without the ribbon, I can probably use CFD-FASTRAN (from CFDRC, USA) to simulate the problem. (FASTRAN can simulate 6-DOF motion in a flow). But in the current problem the flexible ribbon plays a very important role, without it, the motion would be totally different. Please let me know if anybody has any ideas on how to solve this problem or suggestions on the aproperiate approaches for this problem. Thanks
Old   November 1, 1999, 12:50
Default Re: flying object with a ribbon attached
Alton J. Reich, P.E.
Since you have FASTRAN, I would recommend contacting CFDRC. I worked on a paper earlier this year with some folks from CFDRC and in addition to the 6-DOF model, some of the simulations in the paper used chimera hole cutting techniques. Depending on the type of movement that you expect the ribbon to experience, you may be able to use chimera techniques to model it.
Old   November 5, 1999, 17:37
Rainer Kurz
Why don't you study a case where the flying object is fixed and only the tail moves, and run the simulation for different relative positions of the flying object. Another suggestion (maybe more fun): Why don't you build this object (sounds to me like a kite) and get some test data.
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Sliding Interface issues philippose OpenFOAM Running, Solving & CFD 7 May 5, 2014 03:13
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
