Calculating mass flow rate
Old   April 3, 2008, 15:13
Default Calculating mass flow rate
cfd novice
Hi Guys
Can some one tell me please what is the relationship between mass flow rate (Ubar) and friction Reynolds number (Re tau). I need to calculate mass flow rate (Ubar) from Re tau. Thanks in advance
Old   April 3, 2008, 18:31
Default Re: Calculating mass flow rate
cfd novice
Basically I am using periodic/cyclic BC at my inlet & outlet. I dont have U or P given, I have only Re tau. How can I calculte velocity from Re tau and then mass flow rate for my channel flow. Thanks in advance for answer.
cfd novice
Old   April 5, 2008, 07:58
sivaramakrishnaiah
you know Re number value ok ro(density)*velocity*damiter/dynamic viscosity for Re number. now you can calculate density in that density you can calculate mass flow rate know ok bye
Old   April 5, 2008, 15:19
cfd novice
Hi sivaramakrishnaiah
How can I calculate mass flow rate from density? Thank You
Old   April 6, 2008, 16:12
alex
mass flow rate = rho*U*A (Rho=density, U=velocity, A=cross sectional area)
Re = rho*U*l / mu (l=characteristic length, mu=viscosity)
So Mass flow rate = Re*mu*A / l
Old   April 7, 2008, 18:45
cfd novice
Thank you for your answer alex.
mass flow rate = rho*U*A (1)
Re = rho*U*A/mu (2)
From (2): Re*mu = rho*U*A
So mass flow rate = Re*mu
How did you get above answer?
Thanks
Old   April 8, 2008, 13:08
alex
Re is based on an length, not the area. Re = rho*U*L / mu
What length you use depends on the problem. L is the characteristic length. You might hear things such as Reynolds number based on pipe diameter for example. Or based on distance from leading to trailing edge of an airfoil.
So... Mass flow = rho*U*A (where A=cross sectional area that the flow is flowing into). --(1)
Re= rho*U*L / mu (where L is the length that you are basing your Reynolds number on) --(2)
Combining (1) & (2) :
Mass flow = Re*mu/L * A
Regards,
Alex
Old   April 21, 2008, 06:38
davoche
there is a relation (from experimental datas) which can help you to determine the flow rate from re in a turbulent flow. Indeed, according to hinze (1975) : re_tau=1/8.3*(Re)^(7/8)
You could also find more element (in french for the moment sorry) at the following link : http://www.olivierdoche.com/images/T...HESE_DOCHE.pdf
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 09:29
Calculating mass flow rate cfd novice FLUENT 1 April 3, 2008 18:31
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
