April 25, 2008, 10:37 |
compressible flow algorithm
Dear friends: I have treated the incompressible flow for several years, by using the famous algorithm of Pantakar, simple alogirthm. Now, i want to have some knowledge in the compressible flow expecially the supersonic compressble flow used in the aerodynamic fields. Would you please give me some good references for a start about the solution algorith for the compressble supersonic flow. Regards
April 26, 2008, 01:55 |
Re: compressible flow algorithm
People have extended the simple algorithm for compressible flows. You might want to look into that unless you are more interested in developing a density-based scheme.
April 26, 2008, 03:49 |
thank you very much, woudl you please give me some good references for the density-based schmeme regards
April 26, 2008, 09:53 |
The CFD book by anderson, pletcher and tanheill discuss the implementation of maccormack and beam-warming schemes for density-based solvers. For finite volume implementation you might want to check Blazek.
-H |
April 27, 2008, 20:41 |
Thank you very much Harish, i am so sorry to bother you again, would you please tell me the name of book by these people. regards
SIMPLE algorithm for compressible flow | and | Main CFD Forum | 6 | August 10, 2015 14:06 |
Compressible Fluid Flow in COMSOL Multiphysics | BBG | COMSOL | 1 | November 19, 2008 14:05 |
urgent help needed with 2d compressible flow | James | FLUENT | 2 | June 20, 2007 04:22 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
On SIMPLE algorithm in compressible flow situation | Abhijeet Vaidya | Main CFD Forum | 3 | October 18, 2001 05:46 |
