Are Pyramid elements good for solvers
Old   June 22, 2008, 14:26
Default Are Pyramid elements good for solvers
Pratik Mehta
Hello friends,
Can anyone explain me in the following doubt
Case:
I am having a volume mesh on a geometry like a waterjacker for SI engine. I plan to create a hybrid mesh ( tet+ prism layers) In some places of my mesh ,I get pyramids . So my question is are pyramids here are an unwanted elements or I should still go ahead with such mesh or sit n redo the mesh till I get rid of pyramids
Thanks for your inputs
Old   June 24, 2008, 04:00
Default Re: Are Pyramid elements good for solvers
jojojo
Pyramids are not the problem in case there are no sharp angles.
Old   June 24, 2008, 06:14
pratik mehta
Now, you saying pyramids are no problem ,in places of smooth geometry, I agree . I would like to have a information consider, I have a intake Port and I have two meshes. One having some pyramids locally at sharp corners (Also as I understand that you would get pyramids only at the places of sharp corners becuase of improper inputs for generating prisms) So here is the doubt ,would you accept the mesh where there are pyramids in such places or a mesh which do not have any pyramids in places of sharp corners.
How much does it really matter to CFD solver.
I would really appreciate your answer for the same.
Thank you
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
Fluent dynamic mesh 'remeshing' method for pyramid elements DarrenC FLUENT 14 December 11, 2015 04:58
2D Meshing - No matter how thin my model is, it is still 2 elements thick RossFS ANSYS Meshing & Geometry 6 April 14, 2010 00:13
Sliver Elements in 3D Delaunay Triangulation Dinesh Godavarty Main CFD Forum 1 July 23, 2003 10:11
Egyption Pyramid with All HEXA Selina Tracy Main CFD Forum 17 March 30, 2001 04:15
