Structured mesh of a 3d sharp trailing edge
Old   May 22, 2008, 10:44
Default Structured mesh of a 3d sharp trailing edge
Gilles
I'm currently working on meshing a 3 dimensionnal wing with a rounded wing-tip. I try to make a structured mesh but there is a problem meshing the trailing edge. Since it is a sharp trailing edge (NACA4418) I can't mesh it in a structured way. Does anyone have some advice to help me mesh my wing tip ? That could be very helpful.
Thanks for the answer !!
Old   May 22, 2008, 13:22
Default Re: Structured mesh of a 3d sharp trailing edge
Harish
You can try using a C-type grid by cutting along the trailing edge and specifying the points on the wake of the wing. Also you can try creating H-grids like they use in Turbomachinery.
Old   May 23, 2008, 13:23
M
I would use an H-grid. Off-set one of the vertex at the trailing edge to the top of the wing. Then use an O-grid from the wing tip to the far field to capture the irregular shape and improve grid quality.
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
Boundary layer meshing with sharp trailing edges Andrew Berner FLUENT 1 August 28, 2007 17:39
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
