is there any solution which can make CFD program stable?
Old   April 26, 2015, 22:20
Default is there any solution which can make CFD program stable?
garry
yzeyue is on a distinguished road
Hi, everyone!
I recently use a CFD program to make simulation, but I found that my program is very unstable when I change some parameter, such as the grid. Mesh is the H-type, so there is not negative mesh, and the angle is not small--orthogonality is good.
When I use the CFD software, there is no such problem before, and the solving speed and the convergency is both fast and good.
So, I want to ask whether there is some method to make the CFD program stable. Is there paper to solve such problems?
Thanks!
Garry
yzeyue is offline   Reply With Quote
Old   April 27, 2015, 01:48
shahrooz
shahrooz.omd is on a distinguished road
Are you using proper under relaxation factors?
shahrooz.omd is offline   Reply With Quote
Old   April 27, 2015, 04:12
garry
Thanks for telling me this point. When I use the software I know the under relaxation factors, but I have not changed it in my CFD solver program. This solver is an old one, and I am the only person who use it in my team.
I want to ask u where the under relaxation is used in the CFD program; is it in the residual subroutine or the flux update subroutine or any other one?
thanks very much!
Old   April 27, 2015, 04:20
garry
Maybe there is no under relaxation factor in my explicit CFD program?????
Old   April 27, 2015, 04:59
shahrooz
if you have an explicit solver then other than relaxation factors you have to choose small time steps for stability.
under relaxation factors are in a part where coefficients are calculated. after calculating aP look for a line like this aP = aP / urfm or ap = aP / alpham then go change the amount of urf, alpha or whatever it is named in your solver to a lower amount.
Old   April 28, 2015, 03:44
garry
I think I should try to change the time steps, or others.
Thank you for your reminding!
Old   April 28, 2015, 03:53
shahrooz
I hope you get it to work this way, good luck and you are welcome.
Old   May 20, 2015, 04:32
Tanmay Agrawal
tanmayagrawal7 is on a distinguished road
Send a message via Skype™ to tanmayagrawal7
In explicit schemes, CFL number is usually the criterion for stability. It should be lesser than one. If you can not find it really, then have a finer mesh and/or a smaller time step. That will do.
tanmayagrawal7 is offline   Reply With Quote
What CFD Program should I use? frownless Main CFD Forum 5 June 17, 2013 03:09
Why I cant use both CFD program at the same time? brksnn Main CFD Forum 0 February 1, 2013 09:05
could someone proose a cfd program for tha above problem kordou Main CFD Forum 0 September 3, 2009 13:57
Select CFD program. Magnus Kalling Main CFD Forum 3 March 10, 2003 16:42
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
