November 13, 1999, 13:01 |
Initialization of VOF
Hi! there,
My friend is simulating free-surface flow using Fluent v.5 (1) It is difficult to give the initial volume of fluid (VOF) using PATCH command since the shape of free surface is complex (2) For using the user defined function. What's the command to give the initial values of VOF? Is it C_F(c,t)? (3) For using a Profile file (with x,y,z,VOF in turn), we do not know how the x,z,z,vof are put into the profile file. Could anyone help my friend? Otherwise, my frined will lose his job. Thanks. J. |
November 13, 1999, 18:41 |
Re: Initialization of VOF
Hi Jenny,
For question 2 and 3 your friend should ask the Fluent-Support and/or read the manual. So lets try to find an answer to Q1. Just think how the things are working in reality? There the water is somwere and the air also. Then something happens which leads to a complex shape of the interface. Thats what you basically have to do with the simulation. Choose a starting point where you know the distribution and start the calculation. Then the shape of the interface will develope over the time. This sounds very easy but it is not!!!! All the VOF stuff is still a bit new and on has to become familiar by starting with simple cases. So don't expect a fast solution. Also the computing time is remarkable, esp. if you have to include surface-tension effects. |
November 14, 1999, 11:00 |
Dear Joern,
Thanks for your message. But sometimes, the initial distribution of VOF is complex, and can not be patched easily. Could you forward your suggestion? Jen |
November 16, 1999, 11:18 |
If his job is in jeopardy, he should've contacted his support engineer at Fluent Inc. What a really bad publicity to us if he loses his job because of FLUENT code ! 1. Can you tell me specifically what sort of initial condition he tries to specify ? Simple topography such as flat surfaces (coordinate surfaces e.g., z= h), rectangles, boxes, circles, and spheres can be easily patched using "Patch" facility in FLUENT 5. If he has to specify complex topography of the free surface, he should use UDF. But I wonder what kind of complex free surface shape he can possibly specify. 2. C_VOF(c,t) is the MACRO for volume-fraction 3. Please read the user's manual. The manual explains everything you need to know in much detail. |
November 18, 1999, 16:41 |
Thanks
Dear Kim,
Thank you very much for your message. >.< My friend already tried to use the Micro. He said, The computed results is bad. The breakup of liquid column under surface tension was also simulated, but there is no difference between the results using 2D cartesian or cylindrical coordinates. Is it a internal bug of Fluent V. 5.02? I have a source code for free surface flow. Thank you again. >@< Jennie |
HELP! adding a mass source to VOF eqn. by UDF??? | ROOZBEH | FLUENT | 5 | December 3, 2016 17:53 |
FMG initialization query | Mohsin | FLUENT | 6 | November 2, 2016 02:02 |
Initialization - VOF | moas | FLUENT | 4 | February 19, 2008 22:35 |
Domain Initialization in 2 phase flow using VOF | moas | CFX | 3 | February 17, 2008 05:19 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
