beginner to cfd
Old   May 21, 2015, 23:00
Default beginner to cfd
saba khan
saba.irsh1 is on a distinguished road
hi
i am a beginner to CFd and i have to do unstrutcured meshing for an aircrafts scaled down geometry. the problems i am facing are
1- i dont know how to scale down a geometry?
2- with what refrence should i set my domain should it be rectangular r circle?
3- what should be the size of domain?
can anybody please help
saba.irsh1 is offline   Reply With Quote
Old   May 22, 2015, 02:21
fresty is on a distinguished road
Which software do you plan to employ for the analysis?
Not sure about the problems you are facing in scaling down the geometry... if the geometric proportions are kept consistent while scaling down.. the dimensionless aerodynamic coefficients would remain the same.. so it would, in my opinion, would be a simple CAD scale down.
I would use a rectangular section (with 10 x Avg. chord length ahead and behind the wing) for mesh simplicity (even if it is unstructured), but again it also depends on the software you plan to use.
Lastly, you may want to use symmetric model to reduce computational power & time which could be post-processed for aesthetics later on.
Hope this answers your questions.
fresty is offline   Reply With Quote
Old   May 22, 2015, 03:07
saba khan
i am using icem cfd software for the analysis
actually my geometry is 1/20 scaled down and i intend to scale it up
and i have started off with a circular domain do you consider it inappropriate? and what is the reason to use a rectangular domain than a circular one?
i am not using the symmetric model i have issues regarding cutting it symmetrically
Old   May 22, 2015, 03:19
There is no specific reason except the fact that rectangular region is easier to mesh if done manually and probably lower tendency for orthogonality issues. If you're ok with circular region then that should not be a problem. Give this thread a read...i presume it is almost a similar case that you're trying to simulate..
http://www.cfd-online.com/Forums/ans...icem-hexa.html
It has a lot to do with orientation of components in the model and the best suited domain shape per application & model but again not something definitive.
If your issues are related to CAD/ geometric modelling software then you may consider spending some time on it and getting it done rather than expending massive computation in analysis..
Old   May 29, 2015, 16:37
KateEisenhower is on a distinguished road
Originally Posted by saba.irsh1 View Post
hi
Hi saba,
Just out of curiosity, what is the purpose of scaling down your geometry?
Thanks in advance,
Kate
KateEisenhower is offline   Reply With Quote
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 00:30
CFD Code + partner required + beginner amol palekar Main CFD Forum 1 July 18, 2004 15:32
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
