May 26, 2015, 00:35 |
Divergence detected in AMG solver
N B Khan
Rep Power: 12 |
Dear Friends
I am trying to follow the tutorial as mentioned in the pdf ( http://www.me.metu.edu.tr/courses/me...20Cylinder.pdf )...but there are 2problems occure My case study is " Unsteady flow over cylinder" 1. during mesh.. warning is " Edge(s) with local min size less than global min size has been defeatured. Please consider use different meshing parameters to preserve features if needed" 2nd error when i applied the boundary condition i.e. inlet=80m/s, wall=shear stree=0, outlet=pressure 0, and cylinder no slip when i try to solve it show error "Divergence detected in AMG solver" the 2nd error is already discussed in forum, but i couldnt find the answer. and still have the same problem...need urgent help Thanks to all friends in advance for consideration and time. Best Regards Niaz |
May 26, 2015, 03:14 |
N B Khan
Rep Power: 12 |
When I uncheck the "axissymmetric model" and use " 2D plannar" option...then the solution starts but the result is very different from the turtorial.....
Divergence detected in AMG solver: pressure correction | xinquanzhoucn | FLUENT | 5 | July 21, 2014 04:49 |
Divergence detected in AMG solver: temperature | otubaba | FLUENT | 7 | October 29, 2013 08:39 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 03:44 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
