May 26, 2015, 13:29 |
SPH query
Tim
Rep Power: 12 |
Just wondering if anyone is aware of a forum for SPH anywhere?
I am looking at the SPH formulation for a pressure gradient. I have defined a x-direction gradient on a unit cube defined by 10000 particles. I have no boundaries. The SPH formulation approximates the gradient correction in the centre of the domain but gives an incorrect value at the x-dir edges due to truncation of the kernel radius. Is there a way to correct for this? Thanks in advance :-) |
May 26, 2015, 13:52 |
Rep Power: 13 |
Hi
The correction part is nicely described in this paper: http://www.ibwpan.gda.pl/docs/ahem/ahem57str061.pdf It works perfectly for gradients. I found it to be kind of unstable when used for the pressure gradient though. I'll might give it another shot later. |
May 28, 2015, 05:10 |
Tim
Rep Power: 12 |
Many Thanks for this :-)
SPH code and validation | Dhruval | Main CFD Forum | 1 | November 3, 2015 15:02 |
autodyn sph | Marcelo | Main CFD Forum | 1 | November 1, 2015 08:54 |
Incompressible SPH problems | ikypye | Main CFD Forum | 3 | May 24, 2013 16:19 |
SPHysics or other free SPH codes | Henrike | OpenFOAM | 2 | June 8, 2010 03:31 |
SPH particle vs. real fragment size | Katarina | FLUENT | 0 | April 8, 2009 09:48 |
