May 21, 2015, 23:00 |
beginner to cfd
saba khan
Rep Power: 10 |
hi
i am a beginner to CFd and i have to do unstrutcured meshing for an aircrafts scaled down geometry. the problems i am facing are 1- i dont know how to scale down a geometry? 2- with what refrence should i set my domain should it be rectangular r circle? 3- what should be the size of domain? can anybody please help |
May 22, 2015, 02:21 |
Rep Power: 12 |
Which software do you plan to employ for the analysis? Not sure about the problems you are facing in scaling down the geometry... if the geometric proportions are kept consistent while scaling down.. the dimensionless aerodynamic coefficients would remain the same.. so it would, in my opinion, would be a simple CAD scale down. I would use a rectangular section (with 10 x Avg. chord length ahead and behind the wing) for mesh simplicity (even if it is unstructured), but again it also depends on the software you plan to use. Lastly, you may want to use symmetric model to reduce computational power & time which could be post-processed for aesthetics later on. Hope this answers your questions. |
May 22, 2015, 03:07 |
beginner to cfd
saba khan
Rep Power: 10 |
i am using icem cfd software for the analysis
actually my geometry is 1/20 scaled down and i intend to scale it up and i have started off with a circular domain do you consider it inappropriate? and what is the reason to use a rectangular domain than a circular one? i am not using the symmetric model i have issues regarding cutting it symmetrically |
May 22, 2015, 03:19 |
Rep Power: 12 |
There is no specific reason except the fact that rectangular region is easier to mesh if done manually and probably lower tendency for orthogonality issues. If you're ok with circular region then that should not be a problem. Give this thread a read...i presume it is almost a similar case that you're trying to simulate..
http://www.cfd-online.com/Forums/ans...icem-hexa.html It has a lot to do with orientation of components in the model and the best suited domain shape per application & model but again not something definitive. If your issues are related to CAD/ geometric modelling software then you may consider spending some time on it and getting it done rather than expending massive computation in analysis.. |
May 29, 2015, 16:37 |
#5 | |
Rep Power: 12 |
Just out of curiosity, what is the purpose of scaling down your geometry? Thanks in advance, Kate |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 00:30 |
CFD Code + partner required + beginner | amol palekar | Main CFD Forum | 1 | July 18, 2004 15:32 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
