Code with reliable free surface capability in a rotating system |
September 2, 1998, 13:01 |
Do you know of any CFD code which would simulate free surface with surface tensi on effect in a rotating fluid reliably. I am trying to model Liquid Galium (Ga) filled bearing. Ga is located in a "reservoir" located on a rotating shaft, while outside this reservoir there is very little gap (between the rotati ng component and a stationary enclosure) through which it can "leak" out. I am t rying to find out design parameters to minimize this leakage. The leaking can be (a) because of rotational effect (centrifugal force) and/or (b) because of surf ace tension effect. STAR-CD has VOF type of free surface, but it does not includ e surface tension effect, I guess one option would be FIDAP, but then again I d o not know how good it is in handling flow in rotational system. If you have any suggestions or experience, or know of any code which can handle th e situation as described above, can you kindly send me an e-mail. Thanks a lot for your help, - Roy Mechanical Engineer GE Corporate R&D choudhury@crd.ge.com |
September 4, 1998, 18:47 |
Re: Code with reliable free surface capability in a rotating system
You might try Flow 3D from Flow Science Inc. It has excellent free surface capabilities including surface tension and rotating systems.
I have been working with Flow 3D for some time and I believe, that it could be of great help to you. To my knowledge, there is nothing comparable to it for free surfaces. Have a look at www.flow3d.com. |
Thermocapillary free surface flow | zakifoam | OpenFOAM Running, Solving & CFD | 10 | December 12, 2016 11:44 |
Can Flow-3D plot the free surface area in Iso-surface or colour variable? | therockyy | FLOW-3D | 1 | June 20, 2010 19:36 |
BC for free surface | pilar | FLUENT | 3 | January 14, 2004 07:36 |
Free Surface Modeling | willy | FLUENT | 11 | July 17, 2001 07:07 |
Free Surface Flows / Ocean Waves / Far-field boundary conditions | Sundar Prasad | Main CFD Forum | 5 | May 4, 1999 10:25 |
