Properties of air versus temperature AND pressure
Old   July 25, 2008, 04:39
Default Properties of air versus temperature AND pressure
Vincent
I'm working with air at high temperature (up to 2573 K) and high pressure (up to 60 bar) and I need ALL the physical properties of dry air versus temperature AND pressure.
for example, on this website http://www.pipeflowcalculations.com/tables/dryair.htm , there is three physical properties of air at different temperature and pressure. But it's too limited : not enough properties, very few pressure and temperature, no reference concerning the information displayed.
I had a look on several website like : http://tpsx.arc.nasa.gov/ , http://webbook.nist.gov/ , http://www.engineeringtoolbox.com/ but I didn't find what I need. Most of the time, properties are given versus temperature only.
Do you know where I could find such information ? There is an International Association for the Properties of Water and Steam (http://www.iapws.org/). Is there the equivalent association for the properties of air where I could find an answer ?
Thanks for your help.
Old   July 25, 2008, 05:04
Default Re: Properties of air versus temperature AND press
Fernando Herrera
Have you tried using critical values of the air to extrapolate the known values of the properties.
Check any book in thermodynamics, there are some relationships there.
You could also have a look at Perry's handbook for chemical engineers
Old   July 25, 2008, 07:16
Vincent
No, I didn't try because, I prefer using well known correlations based on precise experimental results. For example, I took the data stored in the NIST website for water and steam because I think the level of confidence is high. And it's what I'm looking for : a sort of standard dry air model like the one which exists for earth's atmosphere ( http://www.pdas.com/atmos.htm ).
Of course, I could find some data in books but it would be much easier to have numerical data or a correlation. I want to avoid (if it's possible) to fill hundred of line and column myself ;-)
I found a lot of tools for steam and water on web. I can't believe there is no reference data for dry air...
Thanks for your help. Anything else ?
Old   July 25, 2008, 09:49
otd
Two possibilities - if you can locate them:
National Advisory Committee for Aeronautics, report 1135, Equations, Tables, and Charts for Compressible Flow, 1953.
NACA is the predecessor agency to NASA.
The other is:
Keenan and Kaye, Gas Tables, copyright by the authors in 1945 & 1948, published by Wiley.
Table 60 is entitled "Standard Atmosphere".
An extensive section entitled "Sources and Methods" gives equations and references to the fundamental data sources in the technical literature.
You might need to do some additional work (if you can find the references), but it appears to be a good place to start.
Good luck!
Old   July 28, 2008, 05:34
Vincent
I have found the NACA report but I don't have the second reference you've mentioned.
As I said previously, I want to avoid (if it's possible) to fill hundred of line and column by myself. That's why, correlation or numeric array (on Excel for example) will be great.
I worked hard this week-end to find such resource on the web : nothing !!!
Any suggestions ?
Old   July 28, 2008, 06:28
Markus Lummer
Hi Vincent,
perhaps you should have a look at
http://www.mhprofessional.com/produc...sbn=0070116822
Hope, this helps.
Regards, Markus
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
