What does Gauss Seidel iteration mean?
I am trying to build the model for bacterial chemotaxis as described in the paper Tyson, Leveque (2000) - Fractional step methods applied to a chemotaxis model. Without going into the details, they are solving the the diffusion term using the trapezoidal rule and the BDF2 method (TR-BDF). I implemented these the standard way, by constructing a tridiagional matrix and then inverting it to get a solution to the implicit problem. Unfortunately I get oscillating solutions. I have no idea what the authors mean by few sweeps of Gauss-Seidel iteration. Is that how I am supposed to invert the matrix? Isn't that very inefficient? Here's the extract from the paper: "We implemented TR-BDF2 by splitting the method dimensionally and then correcting for cross terms by using a few sweeps of Gauss-Seidel (or under-relaxed Jacobi) iteration. The first stage of the method, TR, is implemented by taking one step of a locally one-dimensional (LOD) method, which is just a fractional step method in which the x- and y -derivative terms are split apart, resulting in simple tridiagonal systems of equations to solve along each grid line [22]. The second stage,BDF2, is implemented first by taking another step of an LOD method, with differ-ent coefficients this time. This gives a very good initial guess for the Gauss-Seidel procedure. In principle advancing by LOD alone should be enough to maintain second order accuracy, but we have found that this can reintroduce grid-scale oscillations." Any help greatly appreciated!!! |
The GS method belongs to the class of iterative solver for linear algebric system, it is not a inversion of the matrix.
However, for tridiagonal system the Thomas algorithm is well suited |
I would need to know the details ...however, if the diffusion operator is a 2D Laplace operator (d2/dx2 + d2/dy2), the factorization technique introduces an error of high order term that can lead to oscillations. You have two successive tridiagonal systems. But in no way an iterative solver can be able to avoid oscillation that are inherent to the type of approximate solution. |
the first step is a simple Crank-Nicolson integration for 1D and the Thomas algorithm is fine
