Parallel computing with AVL FIRE
My system has core2quad CPU,and I have noted that during the run of the program FIRE 8.5 on win XP, just 25% of CPU (1 out of 4) is used. As I have found, To use all CPUs it needs Parallel processing capability. But this capability can not be used with win XP Operating System. Can Anyone help me please?
Re: Parallel computing with AVL FIRE
Dear doki I myself use the AVL Fire V8.31 and the parallel processing can't be done on the multi core CPUs!
I don't know about the V8.5 and I can say that if you can do a batch job on the calculations then you can do the multi core to work . for example on the FEP projects the batch job will allow the multi core usage . by the way can you tell me if you can give me the V8.5 are you a licensed user or you have a cracked version . contact me via Email! |
