Flow-3D for Steady State Simulation
Old   August 15, 2008, 04:07
Default Flow-3D for Steady State Simulation
CK
Hi All, Does anyone know how to do steady state simulation (involved both fludis flow and heat transfer) with Flow-3D?
Thanks and Regards CK
Old   August 16, 2008, 12:25
Default Re: Flow-3D for Steady State Simulation
kostaspan
Hi. Firstly you must make a 3-dimentional model which you want solute. The *.*msh file of your model will be opened by fluent for 3d models. You chose "3d" option when open the fluent. After input your file and determine some parameters. These parameters are:
1. For "steady" analysis will you go at the menu bar: Define->models->Solver and at the windows which has been opened, choose in the "Time" frame the option "Steady".
2.If you want to include and heat transfer you go: Define->models->Energy and you choose the energy equation.
The other steps are same with the 2d simulation...
Old   August 16, 2008, 16:36
otd
Check flow-3d.com. Get the phone number and call them. Or email support@flow-3d.com.
Also see if there's a flow-3d forum on cfd-online.
Good luck!
Old   August 22, 2008, 02:20
CK
Kostaspan & Otd Thanks a lot for your inputs.
Rgds CK
Old   December 27, 2020, 09:25
Default For finding Steady State flow condition
Susan Vaidya
susanraj is on a distinguished road
Dear all,
As I am new to Flow-3D and I am working with my thesis for the scouring in the downstream of stilling basin.
Can anyone help me to mark the steady flow condition to consider it as the restart for later run while running the simulation?
susanraj is offline   Reply With Quote
Old   March 2, 2021, 06:29
UK
redlemon44 is on a distinguished road
This is for Fluent, not FLOW-3D. For FLOW-3D, use the steady state accelerator in numerics and also the termination criteria under Time>Finish options
redlemon44 is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Channel flow setup in Large-eddy simulation Weihua Main CFD Forum 6 November 17, 2015 09:33
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 10:54
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
