August 20, 2008, 17:06 |
problem meshing in GAMBIT
hi all...
I a little bit problem in meshing by using GAMBIT software... My project is need to determine laminar flow in rectangular minichannel ( 1mm x 1mm )... after done drawing 1mm x 1mm square, then face it, then i try mesh face and choose interval count = 100, so as the result i get as this http://img171.imageshack.us/img171/8364/1mmx1mmkm3.jpg why it show curve at 4 corners? why this happen? how can i fix it? or it is normal so small size? then i try meshing with same shape but this time is 1m x 1m, an as a result, i get this http://img165.imageshack.us/img165/1...x1meternd5.jpg http://img165.imageshack.us/img165/1...97500bc405.jpg or http://img165.imageshack.us/my.php?i...x1meternd5.jpg its look ok this time..no curves around its 4 corner... so anyone, please help me to fix this...or any idea? thanks for read.. best regard Last edited by wyldckat; September 3, 2015 at 16:20. Reason: disabled embedded images |
August 20, 2008, 17:13 |
Re: problem meshing in GAMBIT
i am sory..
the picture for the 1mm x 1mm mesh is http://img171.imageshack.us/my.php?image=1mmx1mmkm3.jpg and 1m x 1m http://img165.imageshack.us/my.php?i...x1meternd5.jpg thanks again help me pls some 1 |
GAMBIT meshing problem for boundary layer | Falah | FLUENT | 2 | November 30, 2020 14:16 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Gambit meshing problem | David Banks | Main CFD Forum | 0 | July 19, 2007 11:48 |
Problem starting Gambit | ViHAR MALViYA | FLUENT | 0 | November 10, 2006 10:26 |
Gambit Meshing Problem | Drew | FLUENT | 3 | April 1, 2005 10:50 |
