Problem with SIMPLE algorithm
Like Tree1Likes
  • 1 Post By katakgoreng
Old   December 27, 2009, 08:24
Default Problem with SIMPLE algorithm
katakgoreng is on a distinguished road
I have written finite difference SIMPLE algorithm to solve the Navier Stokes equation in Matlab. My problem is that I don't know how to specify boundary condition for Poisseuille flow. If i specify inlet velocity, the solution tend to blowup. I suspect that somehow I don't specify the pressure boundary correctly.(In the matlab code if I specify the pressure boundary for inlet and outlet but no velocity boundary at the inlet, the solution does not blow up but the problem is that I cannot control the inlet velocity) I managed to solve Couette flow and Driven cavity problem with no problem though..Care to advice me on what I have to do. I attached also the code for the SIMPLE algorithm that I write..
Last edited by katakgoreng; December 27, 2009 at 08:48. Reason: need to give mo info
katakgoreng is offline   Reply With Quote
Old   December 27, 2009, 10:13
Default boundary condition
jk
jyothishkumar is on a distinguished road
You are solving flow in a duct basically. Use velocity inlet and pressure outlet bc. Which grid r u using ? colocated or staggered
jyothishkumar is offline   Reply With Quote
Old   December 27, 2009, 10:21
I'm using staggered grid..if i set the inlet velocity to v=1 and pressure outlet p=0, how about inlet pressure, do i need to extrapolate it with inner pressure?
Old   December 27, 2009, 23:02
jk
yes exactly. p(1).value = p(2).value where p is the pressure and numbers indicate the node location
Old   December 28, 2009, 04:09
hmmm..it's that simple? i'll try it..
for anyone who has run my code, do comment on what I have done..thanks in advance..
guanjingduibuqi likes this.
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
A simple heat transfer problem ? iggor FLUENT 1 June 15, 2009 04:42
SIMPLE algorithm for collocated storage alex Main CFD Forum 4 April 8, 2008 23:48
DPM - simple problem (I think) Maciej FLUENT 0 November 9, 2005 16:28
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 06:19
