shahrooz.omd |
July 13, 2015 07:07 |
Mass flux correction in SIMPLE
Hi, as my unanswered previous posts indicate, I have a problem with my SIMPLE code while I use variable density. As an everyday routine (for a month already) I was reading books, googling and studying my code then I came across this detail in OpenFOAM wiki and also in CFD-online wiki:
- Set the boundary conditions.
- Solve the discretized momentum equation to compute the intermediate velocity field.
- Compute the mass fluxes at the cells faces.
- Solve the pressure equation and apply under-relaxation.
- Correct the mass fluxes at the cell faces.
- Correct the velocities on the basis of the new pressure field.
- Update the boundary conditions.
- Repeat till convergence.
I don't correct mass fluxes after solving pressure correction equation however, my code works fine when I use constant density, it even works fine when I use variable density for all subroutines except pressure correction. Mass flux correction is not mentioned in Vertseeg book nor in patankar's. Where can I learn more about this step and can someone confirm if this is the cause of larger errors when I use variable density?
