July 17, 2015, 07:08 |
Enthalpy based energy equation
shahrooz
Rep Power: 14 |
Can anybody direct me to an article / book on how to treat enthalpy based energy equation in numerical solution.
any help is appreciated. |
July 17, 2015, 08:37 |
Lucas
Rep Power: 10 |
I think you should state your question a little more specific. Do you:
> need information on the actual statement of the enthalpy based energy equation? > need information on discretisation for FV/FD/FE methods? > need information on the actual solution of the resulting system of equations > need other information, etc. ... Right now from what I assume is that you need general information on this topic, so I would recommend books that cover all the questions above. A good start would be "Computational Fluid Mechanics and Heat Transfer" by Richard H. Pletcher. http://iate.oac.uncor.edu/~manuel/li...20Anderson.pdf If you get more specific with your question it might be easier for other users to give recommendations. |
July 18, 2015, 18:55 |
#3 | |
shahrooz
Rep Power: 14 |
July 18, 2015, 18:58 |
shahrooz
Rep Power: 14 |
I have written a working SIMPLE code which uses temperature based energy equation, I want to change that to entalpy/temperature based energy equation.
July 19, 2015, 15:51 |
#5 | |
Filippo Maria Denaro
Rep Power: 71 |
you can use the equation for the total energy rho*(Cv*T + V^2/2), the advantage is that you can use the conservative form |
July 19, 2015, 16:54 |
shahrooz
Rep Power: 14 |
July 19, 2015, 18:04 |
#7 | |
Rep Power: 71 |
I don't know about this kind of problem but I am quite confident you can define a specific total energy of the supercritical fluid system by defining properly the internal energy from your multiparameter equation of state |
Display Modes | |
Energy equation based on enthalpy | shahrooz.omd | Main CFD Forum | 0 | July 1, 2015 02:46 |
Problem about sensible enthalpy in Fluent energy equation | Echo | FLUENT | 0 | January 5, 2015 03:50 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Viscosity and the Energy Equation | Rich | Main CFD Forum | 0 | December 16, 2009 14:01 |
about energy equation | chuanyue | FLUENT | 4 | October 19, 2009 10:44 |
