Galerkin Method Applicable for Finite-Volume?
Old   September 7, 2008, 19:02
Default Galerkin Method Applicable for Finite-Volume?
Scott
I am developing a CFD model of a continuous reactor. The model is three-dimensional, cell centered, finite-volume formulation in rectangular domain using Cartesian co-ordinates. The SIMPLE method is being used with staggered grids. I would like to use the multi-grid method to solve the pressure correction equations. I have a few questions about my approach. Is it acceptable to use the Galerkin (A1=R2A2P1) method to generate course grid coefficient matrices from fine grid coefficient matrices or is it better to re-discretize the equations? Is it valid to represent one transfer matrix (R) as the transpose of another (PT) or should R and P be developed separately? Are there compatibility restrictions on R and P matrices that are developed separately? Is it acceptable to use a weighted average restriction matrix R, along with a tri-linear interpolation matrix P? Thanks you for your help Scott
Navier stokes and the standard Galerkin method micheldup Main CFD Forum 0 March 1, 2011 09:24
Weak statement for Galerkin Method rugabug Main CFD Forum 0 March 26, 2010 19:19
discontinunous galerkin method jack Main CFD Forum 2 July 29, 2007 14:02
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
finite volume method for CFD analysis of 2D blunt body Aditya Vaze Main CFD Forum 1 January 19, 2000 13:55
