TVD schemes for acoustics
Old   September 16, 2008, 20:32
Default TVD schemes for acoustics
Shuo
Hi
Is it logical to use TVD schemes for compressible acoustic simulations even though it is inherently an artificial viscosity method? If not what other methods are there?
Shuo
Old   September 17, 2008, 04:25
Default Re: TVD schemes for acoustics
versi
not very good because of too much diffusivity of TVD scheme in acoustics. Compact schemes, DRP schemes are better.
Old   September 17, 2008, 04:32
shuo
How about WENo/ENO type schemes?
Old   September 17, 2008, 10:44
Brian
what is Compact schemes and DRP schemes ? please explain !
Old   September 17, 2008, 14:26
Harish
WENO/ENO type schemes are fine. Also you can look at ADER schemes. If you do not expect to observe shock structures in your flow field, the compact and drp schemes are much faster compared to the ENO schemes. Also compact and drp schemes can also be applied for flows with shock structures by adding filtering ( see papers of visbal) or dissipation ( see papers of Tam). The other option is to use upwind compact ( paper of zhong) and upwind DRP schemes ( CAA benchmarks) or consider other classes of high order schemes ( high-order mccormack etc., search for the review paper by Kurbatskii) which include in-build dissipation. You should have a look at the CAA benchmark workshops for the variety of high-order schemes that you can employ for your computations. You need high-order BC with high-order schemes to avoid degrading your solution especially near walls.
Old   September 19, 2008, 21:47
Axel Rohde
A colleague of mine and I published a paper on this a few years back, where we compared my TVD acoustic solution to his aeroacoustic solution for M = 0.5 cylinder flow. Here the link to the PDF: www.microcfd.com/papers.htm
TVD Schemes in OF joern OpenFOAM Programming & Development 5 July 7, 2010 15:34
TVD schemes: 2 questions Shuo Main CFD Forum 0 August 19, 2008 21:51
TVD schemes Shuo Main CFD Forum 3 July 3, 2007 22:04
TVD Schemes Sudeep FLUENT 0 October 14, 2000 21:31
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 04:21
