energy equation in terms of entropy
Old   September 18, 2008, 05:37
Default energy equation in terms of entropy
kiran
Hi is it possible to have energy equation in in terms of entropy. thanx.
Old   September 18, 2008, 09:09
Default Re: energy equation in terms of entropy
mettler
just as a quick thought: I know you can get it in terms of enthalpy and enthalpy has Q, which is in the entropy integral. I have never seen it or derived, so I am not sure if there would be any snares when trying to derive it.
Old   September 19, 2008, 03:56
Paolo Lampitella
Of course, it is. It should be (for a Newtonian - Fourier fluid):
rho * T * DS/Dt = div(Kh * grad(T)) + k * div(u)^2 + 2 * mu * (Sij - 1/3 * div(u) * dij) * (Sij - 1/3 * div(u) * dij) + rho * E
where:
rho = density
mu = dynamic viscosity
u = velocity vector
S = entropy
E = source term
DS/DT = dS/dt + div(uS) = material (or substantial) derivative
Kh * grad(T) = thermal flux (following fourier)
k = lambda + 2/3 * mu = bulk viscosity (usually set to zero following Stoke's Hypotesis)
dij = i,j component of the Kronecker's delta tensor
Sij = 1/2 * (dui/dxj + duj/dxi) = i,j component of the symmetric part of grad(u)
(Sij - 1/3 * div(u) * dij) * (Sij - 1/3 * div(u) * dij) = Aij * Aij = trace of the tensor A*A (A squared)
It is difficult to distinguish the different operators but should be clear
Old   September 20, 2008, 04:49
Ahmed
The Energy equation, is a statement of the first law of thermodynamics,i.e. the principle of conservation of energy, on the contrary, entropy, is a property of matter that is always increasing as long as there is a change of state. You can write a transport equation for the entropy (Check the book bt Vedat Arpaci Convection Heat Transfer)but not a conservation principle. I hope you get the picture and see the difference. Good luck
Old   September 20, 2008, 05:11
Paolo Lampitella
Of course, i was not clear about this. This is a second law of thermodynamics statement, nothing to do with first law.
In fact, the equation writed is not a conservation principle.
Old   September 22, 2008, 09:52
Kiran
Hi, Thanks a lot !!!
Solving the total energy equation dohnie OpenFOAM 21 June 13, 2014 00:44
Entropy equation as a fourth equation (5th in 3D) sarium Main CFD Forum 0 April 6, 2009 18:04
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
question about energy equation zhou FLUENT 0 February 23, 2004 23:55
Energy equation Suresh Balasubramanian FLUENT 1 April 6, 2003 02:54
