August 13, 2015, 05:00 |
Boundary conditions
Rep Power: 15 |
Hey,
Many textbooks suggest a mix of boundary conditions to be prescribed at the boundaries. For instance at solid walls, usually a zero velocity condition is prescribed and a pressure condition is calculated with the use of the continuity equation and whatever discretization method is used for the momentum equations (dp/dn=0 is a common outcome of this). My question is - why prescribe a pressure boundary condition at all? Is it not possible to solve the (interior) equation for pressure at the walls where the velocity is specified? Likewise for velocity when the pressure is specified at a boundary etc. |
August 13, 2015, 05:51 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Each problem requires the proper set of BC.s to be well posed... the pressure problem is elliptic and requires only one boundary condition. Generally, the physics of the problem allows us to express the knowledge of the normal velocity component, for example on a wall. This is the only condition we set to close correctly the pressure equation. The value dp/dn is not fixed but it is a consequence of the velocity BC.s according to the Hodge decomposition Grad p = v* - v Of course, you can work by fixing dp/dn but then you can fix also n.v. Note that dp/dn = 0 on a wall is a low-order approximation when the Reynolds number is not sufficiently high since would imply n.v*=0 |
August 13, 2015, 06:46 |
#3 | |
Rep Power: 15 |
August 13, 2015, 06:56 |
#4 | |
Rep Power: 71 |
The first thing is using the physical BC.s: if you know the velocity use that, if you know pressure use that.... The pressure problem cannot be closed by fixing a value in a cell! It is an elliptic problem that requires mathematically the BC.s to be posed on all boundaries. Sorry to say that I see some confusion in your idea about the pressure problem.. |
August 13, 2015, 07:24 |
#5 | ||
Rep Power: 15 |
Yeah, this is why cfd-online is so great! |
August 13, 2015, 07:35 |
Rep Power: 71 |
very often the velocity is an available data for BC.s, few cases are suitable to be afforded with pressure...however, we do not need to know the pressure on a wall but only the relation for the normal derivative.
The continuity equation drives us to write the Poisson equation (in the interior) but to set a mathematically well-posed problem, the Poisson equation must be supplied by proper BC.s on the boundaries. When the BC.s are prescribed, you can modify both the matrix line and the source term. I remember a previous post on cfd-online with many details about |
August 13, 2015, 11:56 |
Rep Power: 71 |
August 17, 2015, 10:34 |
Manish
Rep Power: 10 |
Can any please tell me how to define boundary condition for a solar collector as i m having lots of problem with it as the residual lines get converged but the message error keeps on repeating that 300 cells have temperature of 5000 k. Please help
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
