How can check the eddy viscosity at the wall with LES
1 Attachment(s)
Hi, I checked my code based on 3D turbulent channel flow model (Re_tau=180).
Staggered grid which contains eddy viscosity at the center of grid is used. Due to the properties are placed on the grid center, I confused about checking the properties of eddy viscosity at the wall. When I plot the time averaged eddy viscosity data, the tendency doesn't look like going to zero. The data starts from y+ = 0.583690705381331. Thanks in advance. |
The static Smagorinsky eddy viscosity model cannot give zero at wall...
Usually, a dumping function is supplied |
As you said, static Smagorinsky eddy viscosity cannot give zero at wall. But when if I wanna check the dynamic eddy viscosity, is there a way to check it? |
