August 24, 2015, 00:41 |
Using CGNS subroutines
Rep Power: 11 |
Hi, I am working on the code writing "boundary-node information" file through CGNS subroutines.
I had compiled lots of CGNS examples from "A User's Guide to CGNS", so now I know what is what about CGNS subroutines(at least about subroutines used in examples that I tried to compile). But I still have no idea which subroutines I should use to get this thing work. Here is what I want; The program that reads up a grid file with several boundary conditions and writes out the boundary-node info., including the number of segments of a boundary condition and connectivities of nodes of which boundary elements consist. For example, a boundary condition is assigned to a surface by a pre-processing program(eg. Pointwise or etc), and the program reads up the grid file. Then the program figures out "the number of segments of which elements consist" and "connectivities of nodes of elements". Then, the program writes out the information. ############################################ "the number of segments of far-field" "connectivity 1(counter-clockwise)" "connectivity 2(counter-clockwise)" "connectivity 3(counter-clockwise)" . . . "the number of segments of solid-wall" "connectivity 1(counter-clockwise)" "connectivity 2(counter-clockwise)" "connectivity 3(counter-clockwise)" . . . ############################################ See fig1 & fig2. There are 2 boundary conditions, solid-wall and far-field. For solid-wall, there are 2 elements consist of 5 segment, while for far-field, there are only 1 element consists of 3 segments. So, the file would be as below. ############################################ 3 23 101 31 5 16 12 21 4 16 21 ############################################ I can see that the subroutine "cg_boco_info_f" returns the number of boundary conditions and types of BCs, node index, etc. But I think "cg_boco_info_f" cannot give me information I need. I need your advice on which subroutines I can use to get my program work for the mission. I am waiting for any reply. Thank you. |
August 24, 2015, 19:14 |
Tom-Robin Teschner
Rep Power: 16 |
If you are using pointwise as your mesh generator (and to store boundary conditions) then you would be surprised that they are handling the cgns file a bit differently. it is very logical to look for the boundary information in the boco subroutines, but as far as i remember, pointwise stores that information in sections and so you need to query cg_section_read_f to get your information.
have you compiled the cgnstools as well when compiling the cgns library? if so, you can have a look at cgnsview (in LIBDIR/src/cgnstools/cgnsview) which will display you the file structure in the terminal (or graphically if you have tcl/tk support), sometimes that helps to understand what is written where and how. cgnsview is particularly interesting as it lets you change the cgns data directly like in a text editor (though i think only in the graphical version) |
August 25, 2015, 07:07 |
Rep Power: 11 |
@t.teschner
sorry for late reply and thanks for reply! actually I made a grid with 2 BCs using Pointwise and my program makes an error at below line. ################################################ if (iptset .ne. PointList) then write(6,'('' Error. For this program, BCs must be set'', + '' up as PointList type'',a32)') PointSetTypeName(iptset) stop end if ################################################ but the grid made by "write_grid_unst.f90(which is one of examples in the guide)" doesn't have any problem at the line. is this what you meant? Again, Thanks for your reply! |
August 25, 2015, 08:01 |
Tom-Robin Teschner
Rep Power: 16 |
no, i was just simply saying that all of your boundary information are stored in sections, well or at least if i remember correctly in sections and boco subroutines. what sort of error do you get at that point?
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[Gmsh] Cgns support for gmsh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 1 | July 13, 2016 11:27 |
Boundary nodes in CGNS format | nba1942 | Mesh Generation & Pre-Processing | 0 | August 24, 2015 00:32 |
writing link between two CGNS files | t.teschner | Main CFD Forum | 1 | February 4, 2014 10:26 |
parallel support with CGNS format not yet implemented | kirkrich | SU2 | 3 | January 18, 2013 15:39 |
