November 23, 1999, 14:16 |
pump volume
Could you please tell me how to calculate pump value with out acctualy testing this is for a school project please help PLease E-mail me your answers at seanbicknell@hotmail.com
November 29, 1999, 10:15 |
Re: pump volume
Your question isn't very clear. From the subject I would guess that you need to figure out the volume of a pump. That can be calculated from the interior volume of the pump minus the volume taken up by the impeller and other internal structures.
If you want the volumetric flow rate of the pump, it is generally determined via test. You may be able to get an estimate of the volumetric flow rate if you know the specific speed and rotational speed of the pump, and the required pump head. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
