hydrogen combustion + benchmark
Hello.
Can anyone suggest me some papers or material, which have experimental results in internal combustion engines using hydrogen as a fuel? The engine could be HCCI or spark-ignition or even diesel engine. I am interested mainly on the measured pressure-diagram, the heat-transfer measurements (if available) and NOx measurements. Also is there any site that has benchmark results for various CPUs, which run CFD codes (not parallel processing)? Thank you in advance. |
Re: hydrogen combustion + benchmark
this might help http://www.grc.nasa.gov/WWW/wind/val...l/channel.html
