November 28, 2008, 07:43 |
Gambit installation under linux
I'm trying to get gambit working under linux but get the following error: LANG en_US.UTF-8 changed temporarily to en_US for gambit use. Starting /usr/Fluent.Inc/gambit2.4.6/lnamd64/gambit ... /usr/Fluent.Inc/gambit2.4.6/lnamd64/gambit: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory A quick look at the FAQ's on Fluent's site mentions something about needing to install openmotif. However, "rpm -qa | grep openmotif" yields; openmotif-demos-2.3.1-1 openmotif-devel-2.3.1-1 openmotif-2.3.1-1 so I think thats installed already. The FAQ's also say that the directory /usr/X11R6/lib64/ should have the file libXm.so.3 in it. However "ls /usr/X11R6/lib64/" yields; modules only. where do I get the required file from. I'm using fedora 8 by the way. Thanks very much in advance for any help. Alex |
December 4, 2008, 01:32 |
Re: Gambit installation under linux
Sometimes the default location for installation of certain files are changed on different linux distros. Did you search your system for existence of the file libXm.so.3 . If you have it somewhere else make sure its executable and create a link in the required directory to point to that file. Hope this helps.
OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 04:29 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
Gambit installation problem | Panos | FLUENT | 4 | March 5, 2009 22:44 |
Fluent and gambit installation into Linux | Rashid | FLUENT | 0 | January 17, 2008 01:43 |
OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 05:41 |
