Pressure relief valve
Old   January 12, 2009, 00:37
Default Pressure relief valve
carno
We are doing some testing on pressure relief valve for pressurized oil. Our test engineer reported the heating of the PRV during operation. I am surprised since there should be cooling during the release of the pressurized oil. As the process is very fast and we assume it is adiabatic it is a case of adiabatic cooling. Isn't it?
Your explanation will help me to understand the process.
Thanks
Old   January 12, 2009, 08:40
Default Re: Pressure relief valve
Bart
I assume the pressurized oil is (almost) incompressible. So there is no real cooling as with a compressible gas undergoing an adiabatic expansion. When the oil contains dissolved gas which is released during depressurization this will have a slight cooling effect. But when dealing with an incompressible fluid you will get heating due to friction.
Old   January 13, 2009, 00:06
carno
Thanks Bart for the explanation. I will dig into it further.
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
How to simulate valve using pressure BC?? Luk_Fiz CFX 4 August 16, 2010 18:27
Pressure enigma. Sara Main CFD Forum 22 July 30, 2009 04:46
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
